Shell770
Jul 23, 2016Initiate
Amazon Echo and Netgear C6300
Has anyone figured out how to get Amazon Echo working with the Netgear C6300? Specifically alarms and timers? I've disabled Port Scan and DoS Protection, and turned on Respond to Ping on Internet Po...
Shell770
Aug 05, 2016Initiate
Hi All,
Thank you for your responses. Always nice when users help each other. I did finally get my Echo working, including timers and alarms, on my Netgear C6300, albeit painfully. Below are the steps I had to take, but know I did these once with no success then decided to do a full factory reset and try again. Everything below worked after a factory reset. Unfortunately, this is not the first time I'v had to perform a factory reset to make my new technology work with this router. Anyway, here is what worked for me:
1- Disable port scan and DoS protection (WAN setup)
2- Enable Repond to ping on Internet port (WAN setup)
3- Select port forwarding to always (port forwarding/port triggering)
4- Create the below six custom services (port forwarding/port triggering) <-- I got this list of ports from Amazon
a. 123 (TCP/UDP)
b. 40317 (TCP/UDP)
c. 49317 (TCP/UDP)
d. 33434 (TCP/UDP)
e. 4070 (TCP)
f. 5353 (UDP)
Everything has been stable for a couple of days, but still holding my breath a bit. Good luck to anyone else!
chewiegoodie
Jan 09, 2017Aspirant
When you checked the Disable Port Scan and DoS Protection did any of the DoS events still show up in your log?
I am having issues with my Ring doorbell after it has been working for many months just stopped connecting for video and audio but notifications are still working for rings and motion. I tried checking the Disable Port Scan and DoS Protection box but events still show up in my log as if it was still activated.
Thanks,
Chewiegoodie
