Shell770
Jul 23, 2016Initiate
Amazon Echo and Netgear C6300
Has anyone figured out how to get Amazon Echo working with the Netgear C6300? Specifically alarms and timers? I've disabled Port Scan and DoS Protection, and turned on Respond to Ping on Internet Po...
johnwloneill
Jan 25, 2017Aspirant
Hi I'm currently trying to change my ports and everything. This is my second amazon echo and the first one was sent back because they thought it was faulty and after an hour on the phone with Amazon on this second one they told me I need to open up ports. They gave me a list of ports excatly like yours but plus one. How did you set up the ports? What did you use for the IP address? I just want to make sure I'm doing it right because I tried opening the ports but it still is't working. Thank you.
DarrenM
Jan 27, 2017Sr. NETGEAR Moderator
Hello Johnwloneill
You use the IP address of the Echo itself you will need to go to the attached devices tab in the settings of the router and it should show the Ip. Then you open the ports for it.
DarrenM
