rerubey64
Feb 09, 2019Aspirant
Amber light on my
So I have a model 6250 and an amber light appeared
Does anyone know how to fix it
> So [...]
Never begin a discussion with "So"; like "therefore", it requires an
antecedent.> [...] I have a model 6250 [...]
"C6250"?
> [...] and an amber light appeared
Where? Is it labeled? Visit http://netgear.com/support , put in
your (actual) model number, and look for Documentation. Get the User
Manual. Look for "Figure 1. Front panel LEDs and side panel buttons".Then, look for "Table 1. Front panel LEDs". Does it say what "amber"
means for that indicator? Further reading might be helpful, too.
> Does anyone know how to fix it [?]
Some psychic who knows which LED indicator is bothering you might be
able to guess. Otherwise, for the rest of us, providing some basic
information might be helpful. For example, beyond identifying the
"amber light", what's connected to the [C]6250? Other than this new
"amber light", are you experiencing any problems?
I have a car, and an amber light appeared (somewhere) on it. Do you
know how to fix it?- rerubey64AspirantSorry if my discussion cause any problems to understand so let me repeat
My model is C6250 and I been having it for quite some time
My provider is Xfinity
Now my moderator is showing the upstream light solid amber
I did check in the Manual but it really didnt help
It all started yesterday when high winds were blowing
I have check other discussions but nothing seem to help me
So please can anyone help me fix my problem> Now my [modem+router?] is showing the upstream light solid amber
That sounds like a problem with your connection to your ISP. Have
you asked your ISP about this problem?> It all started yesterday when high winds were blowing
Perhaps a cable (or some other outdoor equipment) was damaged.
Ask your ISP?
