pmc3050
Jul 22, 2017Tutor
Amber Upstream Light
I have a C6300 AC1750 modem & router with firmware version 2.01.20 (I think this is the most current version). The upstream light is amber, and I find that I occasionally have connectivity problems. ...
Akeeb4316
Jan 24, 2018Aspirant
I have the same problem too but except I used to have a solid amber and get internet connection and then after a while the internet connection goes away even when the light turned green but still receive the wireless radio and sometimes I won't get the full download speed. Now presently after restarting a bunch of times and hard resetting maybe twice even unplugging the power cable and plugging it back in, I am currently having a solid amber upstream light and a green blinking downstream light with internet connection that's not really stable. I don't know if the green blinking is an issue. I have Xfinity Comcast as my isp. Please tell me what the issue is and how I can fix it?! Here are my upstream and downstream.
KKB13
Jul 20, 2018Aspirant
Hello. I’m having the same exact issues w/ the amber upstream light, which is constant. My MacBook Pro is having a hard time connecting & continues toggling between Looking for networks” & “On.” Attached is my report. Thanks!
- vkdeltaJul 20, 2018NETGEAR Employee Retired
you have signal issue. Your upstream power too high and beyond specs. that is why you have only 1 upstream channel and it shows amber.
All the powers for US need to be around mid-high 40s and this is at 57dBmV.
- KKB13Jul 20, 2018Aspirant
Either you have too long runs of coax cable in your house, or you have too many or too big splitters or the signal coming into your house itself is too much attenuation in upstream path.
If you cannot fix something in your house, you need to call Comcast and ask them to "lower the upstream power by reducing the attenuation in the path" technicians know it. Ask them to keep it around mid-40s.
