pmc3050
Jul 22, 2017Tutor
Amber Upstream Light
I have a C6300 AC1750 modem & router with firmware version 2.01.20 (I think this is the most current version). The upstream light is amber, and I find that I occasionally have connectivity problems. ...
Akeeb4316
Jan 24, 2018Aspirant
I have the same problem too but except I used to have a solid amber and get internet connection and then after a while the internet connection goes away even when the light turned green but still receive the wireless radio and sometimes I won't get the full download speed. Now presently after restarting a bunch of times and hard resetting maybe twice even unplugging the power cable and plugging it back in, I am currently having a solid amber upstream light and a green blinking downstream light with internet connection that's not really stable. I don't know if the green blinking is an issue. I have Xfinity Comcast as my isp. Please tell me what the issue is and how I can fix it?! Here are my upstream and downstream.
PButer012
Dec 27, 2018Aspirant
I also have the problem with an amber upstream. I seem that everything is okay except the power level please check. Thanks.
