AYung
Oct 21, 2016Follower
Android tablet connected to wifi but not internet
One of my android tablets suddenly cannot connect to internet despite connected to the router. Did try to put in a static IP on the android device, still not working. but the tablet does connect to i...
DarrenM
Oct 24, 2016Sr. NETGEAR Moderator
Hello AYung
if you didnt set up device blocking then nothing should be blocking the device. I would try to tell the android device to forget any network that has the same name as the one you are trying to connect to.
DarrenM
