Parmenedes
Feb 27, 2021Tutor
Any chance of SQM coming to the CAX80
We bought this modem/router a few months ago and have been having trouble with buffer bloat. I stream video games, and my wife and I both work from home (like basically everyone else these days who ...
Parmenedes
Mar 01, 2021Tutor
Thanks for the responose.
Comcast has definitely provisioned the modem correctly. We had some problems initiallly and had a tech come out to the house who replaced a bunch of connectors that had gotten rusty or whatnot, got rid of a splitter, and adjusted the power settings so since they were not at the correct levels (my wife and I had verifired this before we called them to come out, which was part of why we had the tech come in the first place. Upstream and downstream power levels are all right where they should be now, and our cables are great. I'll look into posting the status page if that would really help. I'm streaming wired only. 1000Mb download, 40Mb up, latency around maybe 10ms, jitter typically less than 4.
Mar 02, 2021Guru - Experienced User
If this is the case then streaming should be fine if on the wire.
Be sure your LAN cables are of good quality. CAT6 is recommended...
