jay_w
Mar 08, 2024Apprentice
Any more updates on the CM3000
Any more updates on the CM3000? I saved 20$ by upgrading from 1Gbs with the flex box to 1.2Gbs without the flex box… I got all excited and then realized that my CM1200 is maxed at 1GB using a sing...
- Mar 08, 2024
IF you have a supporting wifi router system that supports LAG on the WAN side, then you could give LAG a try on the CM1200 and see if you see anymore increase in speeds.
NG doesn't give out information when new stuff will be seen. Will need to keep an eye on NGs store or in the retail sector to see when it will appear.Any and all updates are between the ISP and NG. I'm sure they are working on things. Takes time.
Mar 08, 2024Guru - Experienced User
