Andystanton911
Jan 15, 2024Tutor
Any update on 5Ghz Upload issue?
Hi everyone,
Yes, as of this evening 1/15/24 this issue is still present. I have the same exact problem. I have reinstalled the OS and I have performed a rollback. I have performed numerous ...
Andystanton911
Feb 07, 2024Tutor
So, NETGEAR informed me that they will not replace the router because I bought it from a third party, mainly Ebay.
Luckily, I was able to return that router and I bought another CAX 80.
I will attempt to get my new router going and will test the upload issue on the 5.0 GHz frequency.
Feb 08, 2024Guru - Experienced User
Where did you get this CAX80 from?
Keep us posted on how it works for you.
