joshua4242
Feb 08, 2022Aspirant
Any way to email logs on CM2000?
I'm having issues with Comcast/Xfinity and T3 timeouts, and would like to show them a day of logs to illustrate how many times my internet goes out. However, the event logs on my CM2000 only holds 40...
- Feb 11, 2022
Power seems a bit on the high side however with in spec. Might check to see if ISP can turn his down just a bit.
However your getting lots of correct and un-correctables which should be mostly near zero.
You need to check the coax line, connectors, ensure connector is fully seated and screwed into the modems coax jack and remove any splitters if possible to test.
ISP should check this line as well UP to the modem.
joshua4242
Feb 11, 2022Aspirant
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 651000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enabled | BPI+ |
Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 25 | 651000000 Hz | 6.4 dBmV | 42.1 dB | 14999 | 3211 |
| 2 | Locked | QAM256 | 1 | 507000000 Hz | 3.8 dBmV | 42.1 dB | 28819 | 5617 |
| 3 | Locked | QAM256 | 2 | 513000000 Hz | 4.0 dBmV | 42.3 dB | 29400 | 6023 |
| 4 | Locked | QAM256 | 3 | 519000000 Hz | 4.0 dBmV | 42.3 dB | 27786 | 6181 |
| 5 | Locked | QAM256 | 4 | 525000000 Hz | 4.0 dBmV | 42.4 dB | 25226 | 5650 |
| 6 | Locked | QAM256 | 5 | 531000000 Hz | 4.0 dBmV | 42.3 dB | 24711 | 5689 |
| 7 | Locked | QAM256 | 6 | 537000000 Hz | 5.0 dBmV | 42.6 dB | 26458 | 6087 |
| 8 | Locked | QAM256 | 7 | 543000000 Hz | 5.3 dBmV | 42.8 dB | 29572 | 6904 |
| 9 | Locked | QAM256 | 8 | 549000000 Hz | 5.6 dBmV | 42.8 dB | 27897 | 5859 |
| 10 | Locked | QAM256 | 9 | 555000000 Hz | 5.7 dBmV | 42.8 dB | 22044 | 3607 |
| 11 | Locked | QAM256 | 10 | 561000000 Hz | 6.0 dBmV | 42.9 dB | 18468 | 3101 |
| 12 | Locked | QAM256 | 11 | 567000000 Hz | 5.7 dBmV | 42.7 dB | 18220 | 3755 |
| 13 | Locked | QAM256 | 12 | 573000000 Hz | 5.9 dBmV | 42.8 dB | 19708 | 4307 |
| 14 | Locked | QAM256 | 13 | 579000000 Hz | 6.2 dBmV | 42.9 dB | 19384 | 4119 |
| 15 | Locked | QAM256 | 14 | 585000000 Hz | 6.7 dBmV | 43.0 dB | 20333 | 4080 |
| 16 | Locked | QAM256 | 15 | 591000000 Hz | 6.7 dBmV | 42.8 dB | 22641 | 4480 |
| 17 | Locked | QAM256 | 16 | 597000000 Hz | 7.1 dBmV | 42.8 dB | 19707 | 3486 |
| 18 | Locked | QAM256 | 17 | 603000000 Hz | 7.0 dBmV | 42.8 dB | 13979 | 2989 |
| 19 | Locked | QAM256 | 18 | 609000000 Hz | 6.8 dBmV | 42.5 dB | 13303 | 2490 |
| 20 | Locked | QAM256 | 19 | 615000000 Hz | 6.6 dBmV | 42.5 dB | 13578 | 2385 |
| 21 | Locked | QAM256 | 20 | 621000000 Hz | 6.9 dBmV | 42.6 dB | 16303 | 2984 |
| 22 | Locked | QAM256 | 21 | 627000000 Hz | 6.8 dBmV | 42.4 dB | 16447 | 3595 |
| 23 | Locked | QAM256 | 22 | 633000000 Hz | 7.3 dBmV | 42.5 dB | 14862 | 3859 |
| 24 | Locked | QAM256 | 23 | 639000000 Hz | 7.2 dBmV | 42.5 dB | 17990 | 3754 |
| 25 | Locked | QAM256 | 24 | 645000000 Hz | 7.5 dBmV | 42.5 dB | 18953 | 3551 |
| 26 | Locked | QAM256 | 26 | 657000000 Hz | 6.9 dBmV | 42.2 dB | 17836 | 2329 |
| 27 | Locked | QAM256 | 27 | 663000000 Hz | 6.8 dBmV | 42.2 dB | 13823 | 1996 |
| 28 | Locked | QAM256 | 28 | 669000000 Hz | 6.8 dBmV | 42.0 dB | 15271 | 2139 |
| 29 | Locked | QAM256 | 29 | 675000000 Hz | 6.6 dBmV | 41.3 dB | 15868 | 2445 |
| 30 | Locked | QAM256 | 30 | 681000000 Hz | 7.1 dBmV | 42.1 dB | 11395 | 2763 |
| 31 | Locked | QAM256 | 31 | 687000000 Hz | 7.2 dBmV | 41.9 dB | 7056 | 2913 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream Bonded Channels
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 25 | 5120 | 17300000 Hz | 51.0 dBmV |
| 2 | Locked | ATDMA | 26 | 5120 | 23700000 Hz | 47.3 dBmV |
| 3 | Locked | ATDMA | 27 | 5120 | 30100000 Hz | 47.3 dBmV |
| 4 | Locked | ATDMA | 28 | 5120 | 36500000 Hz | 44.0 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 | 0 Hz | 0.0 dBmV |
Downstream OFDM Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0 ,1 ,2 ,3 | 33 | 780000000 Hz | 8.1 dBmV | 41.1 dB | 1108 ~ 2987 | 11476205409 | 1436164848 | 230208 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
| 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
Feb 11, 2022Guru - Experienced User
- joshua4242Feb 17, 2022Aspirant
I completely redid my setup and moved the modem as close as possible to where the cable enters the house. The problem seems to have disappeared, with no uncorrectables over the last 48 hours. It looks like previous placement for the modem travelled along 3 segments of coax inside the house, and one of them is very hard to reach. The xfinity techs only replaced the easy to reach sections, so they never actually fixed the segment that was causing the problem.
- FURRYe38Feb 18, 2022Guru - Experienced User
Ya think they would have caught that. Well, Glad you got it working.
Enjoy. 📡
