GoPadres
Jan 26, 2021Aspirant
Any way to have an ethernet connection bypassing my router with CM1100 modem?
Hi, so I've been troubleshooting some packet loss and latency issues and I've found that connecting my PC directly to my CM1100 seems to give me a slightly better experience. It doesn't solve all of ...
- Jan 26, 2021
Wont work like that.
If your ISP supports having another WAN IP address on the other port, then you could connect a 2nd router to the other port on the CM modem.
What wifi router system do you have connected to the CM modem?
GoPadres
Ok I'll have to look into that extra WAN IP with Cox, I did not know that was a possibility. Thanks for the tip! Yeah I was super dissapointed when I realized the second port was for LAG lol, might've went with a different modem.
Something else just occured to me. Maybe I could add another router into my setup? I could go: Modem->ethernet switch->two different routers (one in bridge mode used solely for my desktop ethernet connection)?
Jan 26, 2021Guru - Experienced User
- GoPadresJan 26, 2021Aspirant
Ok I see. I have a Orbi RBR750 with two sattelites. FW updated to the new 1/21/21 release. I've been connecting to the main router via ethernet, but getting crazy latency spikes and packet loss. Today I had 40% packet loss on the Orbi (first hop). But, sometimes it as if the latency jumps/packet loss are coming from upstream. Its probably mostly just COVID related ISP issues, but I just want to make the most of what I have. I will just pray that my ISP lets me use that second WAN port
- FURRYe38Jan 27, 2021Guru - Experienced User
:smileywink:
