Parmenedes
May 07, 2021Tutor
Any word on when firwmare for CAX-80 (AX6000) will be updated?
Firmware version 2.1.1.4 completely screwed up my multi-gig port, which was the main reason we bought this router in the first place. It was working fine until this firmware version was pushed to my...
Aug 08, 2021Guru - Experienced User
Any progress on this?
Parmenedes wrote:
Firmware version 2.1.1.4 completely screwed up my multi-gig port, which was the main reason we bought this router in the first place. It was working fine until this firmware version was pushed to my unit by Comcast, and factory resets don't work since Comcast just pushes the firware update to it after the reset. The problem is that it drops the connection periodically on any machine plugged into it. I've gotten nowhere with Comcast or Netgear tech support (as usual, they each blame the other party). I've read other posts in various places about this happening after said firmware update, usually from Comcast customers.
Anyway, I've kind of given up on fixing it at this point and am just wondering if there's any word on new firmware being released anytime soon.
