GiuSa58
Sep 09, 2019Aspirant
Apertura porte
Sto cercando di aprire la porta 5000 sul mio router D6400, eseguo la procedura, nella pagina del router la smarca regolarmente sull'indirizzo del mio PC, ma, se vado a verificare con diverse tools, l...
Sep 10, 2019Guru - Experienced User
Please post about this over in the DSL forum:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
English please.
Good Luck.
- GiuSa58Sep 10, 2019Aspirant
I entered the router, then advanced options, port forwarding; selected TCP and opened port 5000 on the IP of my PC, but the port is still closed, checked with "CanYouSeeme.org", with "yougetsignal" and with "ShieldsUP".
- FURRYe38Sep 11, 2019Guru - Experienced User
Good Luck. - michaelkenwardSep 12, 2019Guru - Experienced User
Start at the beginning. What are you trying to achieve?
Why did you do this?
You will have to forgive the conflicting advice you get on where to post your messages. One person says post somewhere else, when you do that someone else tells you not to duplicate things.
Just do what works best for you. They don't run the show.
- GiuSa58Sep 12, 2019Aspirant
I need to connect an NVR to Dropbox
