GiuSa58
Sep 09, 2019Aspirant
Apertura porte
Sto cercando di aprire la porta 5000 sul mio router D6400, eseguo la procedura, nella pagina del router la smarca regolarmente sull'indirizzo del mio PC, ma, se vado a verificare con diverse tools, l...
GiuSa58
Sep 10, 2019Aspirant
I entered the router, then advanced options, port forwarding; selected TCP and opened port 5000 on the IP of my PC, but the port is still closed, checked with "CanYouSeeme.org", with "yougetsignal" and with "ShieldsUP".
michaelkenward
Sep 12, 2019Guru - Experienced User
Start at the beginning. What are you trying to achieve?
Why did you do this?
You will have to forgive the conflicting advice you get on where to post your messages. One person says post somewhere else, when you do that someone else tells you not to duplicate things.
Just do what works best for you. They don't run the show.
- GiuSa58Sep 12, 2019Aspirant
I need to connect an NVR to Dropbox
- michaelkenwardSep 12, 2019Guru - Experienced User
With luck, someone will know what an NVR is.
Network Video Recorder? And the make is?
Yes, video surveillance kit
