oldcroat
Sep 20, 2016Aspirant
Apple TV cannot connect to C3700 Modem/Router
I have a Model C3700 which will not connect to Apple TV. Using the Netgear firmware, and click on the Wireless tab. I can see all iphones and ipads connected. I do not see the Apple TV. In additi...
DarrenM
Sep 29, 2016Sr. NETGEAR Moderator
Hello oldcroat
Make sure your apple TV is up to date with the software and firmware. Also you may want to check if you need to do any port forwarding.
DarrenM
