cyberbiker
Jan 23, 2020Guide
Are All Nighthawk AC1900 R7000 Routers Cable Modems?
I am buying a used Nighthawk AC1900 R7000 for home WiFi and as a cable modem for Charter Spectrum .
Should all AC1900 R7000 routers work as Spectrum cable modems as well?
All R series routers are just routers only. There is no modem built in. If you need a router with a built in modem, then any C series modem will have both a cable modem and router all in one unit for Cable ISP services. If your on DSL, then any D series modem will have both a DSL modem and router all in one unit for DSL ISP services.
Please refer to the ISP for what is officially supported on there network before you buy.
- Thanks! Just what I needed. I wish such clarity was on the website as we were searching for the right piece of equipment.
I’m trying to find a cable modem with WiFi for a weekend house similar to the C6300-BD I use in my home, fit your website doesn’t make it easy.- FURRYe38Guru - Experienced User
Try this link to NGs product page for cable modems with built in routers:
https://www.netgear.com/home/products/networking/cable-modem-routers/
Good Luck.
