Retired_Member
Aug 01, 2019ASUS RT3100 not connecting to Cable Modem C3700
There was a Xfinity outage due to weather and when service came back I had to reset both the cable modem and router. I had to call Xfinity to reset / test the modem and now have WiFi working - but th...
- Aug 11, 2019
> [...] I finally got to setup up the Netgear in bridge mode [...]
> [...] Wired directly to the Netgear also does not accept 192.168.0.1
> [...]That address should work if the C3700 is configured as a
modem+router. As a (DOCSIS) modem-only, you might try "192.168.100.1".
Aug 01, 2019Guru - Experienced User
Either bridge the C series modem or keep the C series modem in router and and set the asus router for AP mode.
- Retired_MemberAug 01, 2019
Thanks FURRYe38 I was able to connect to the C3700 (router Mode) and ASUS (AP mode) but my original plan was to take adv of the ASUS as the router.. what I did
- Disabled the C3700 router mode
- Enabled the ASUS as router
but the ASUS does not connect to the model - solid red light after reboot.. I have attached my settings doc; I must be missing something in the modem settings..
Thanks
- FURRYe38Aug 02, 2019Guru - Experienced User
The Router Mode feature on the C modem needs to be set to NO. This will bridge the C modem setting it for Modem only, then configure your ASUS router for router mode, not AP mode.
- Retired_MemberAug 11, 2019
FURRYe38 Sorry for the delay - I finally got to setup up the Netgear in bridge mode with my ASUS RT-3100 - everything is working fine except I cannot loginto the Netgear modem - the ASUS has a WAN IP that's 24.30.xx.xx ...
Wired directly to the Netgear also does not accept 192.168.0.1 - what am I doing wrong?
Thanks
