nghappy
Jul 03, 2022Aspirant
Attached new CM700 to my old R7000
I replaced my CM500 which had stopped working with a new CM700 today. I connected my Surface Pro 6 running Windows 10 directly to the CM700 and contacted my ISP (WOW). I gave the ISP the MAC addr f...
- Jul 03, 2022
Hi Guru,
Thanks for responding. Problem wasn’t the Netgear modem nor the Netgear router. The cable between the router and modem is okay, but the 3’ cable from the router to the computer is the culprit. Once I replaced this cable, everything is working perfectly.
Thanks for your response. I appreciate it very much.
Best regards,
Ralph
Jul 03, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
nghappy
Hi Guru,
Best regards,
Ralph
- FURRYe38Jul 03, 2022Guru - Experienced User
CAT6 is recommended.
Enjoy. 😉
