djsteele1
Jul 23, 2017Aspirant
Automatic switching from 2.4 to 5.0
Why does my connection on this cable modem wireless router keep dropping. I either connects to Guest or drops on 2.4g or 5.0g. Is there a software or firmware updte to solve this issue.
JamesGL
Jul 27, 2017NETGEAR Employee Retired
Hi djsteele1,
What is the model number of your router?
You may check http://netgear.com/support/ for firmware updates.
djsteele1
Jul 31, 2017Aspirant
I think this is my Model Number at least that is what is on the backside. How do you know what version it is exactly? I know it is a AC1900 Model: C7000 - but there are no other indications on the back of the router. Thanks
- DarrenMAug 02, 2017Sr. NETGEAR Moderator
Hello djsteele1
Have you tried to adjust your wireless channels in the routers wireless settings.
DarrenM
