AJA2024
Sep 09, 2024Aspirant
Aveno VoIP & Netgear AC1750 C6300v2
I have an OBi200 ATA adapter connected my Netgear AC1750 C6300v2 and I have Aveno and Google Voice VoIP service associated with the OBi200 ATA adapter. 99% of my calls are made and received via Anveo...
- Sep 11, 2024
I resolved the matter by performing a reset (seven seconds) of the modem. I purchased the modem used and so the previous owner must have had settings (or the modem just required a reset) that was causing the issue I was having with Anveo VoIP outgoing calls.
Sep 10, 2024Guru - Experienced User
Something to try.
I'd contact the Aveno Mfr to ask for additional help and information regarding there product since that's the one item that doesn't seem to work well while others do.
AJA2024
Sep 11, 2024Aspirant
- FURRYe38Sep 11, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
