AJA2024
Sep 10, 2024Aspirant
Aveno VoIP & Netgear AC1750 C6300v2
I have an OBi200 ATA adapter connected my Netgear AC1750 C6300v2 and I have Aveno and Google Voice VoIP service associated with the OBi200 ATA adapter. 99% of my calls are made and received via Anveo...
- Sep 12, 2024
I resolved the matter by performing a reset (seven seconds) of the modem. I purchased the modem used and so the previous owner must have had settings (or the modem just required a reset) that was causing the issue I was having with Anveo VoIP outgoing calls.
AJA2024
Sep 12, 2024Aspirant
Sep 12, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
