AJA2024's avatar
AJA2024
Aveno VoIP & Netgear AC1750 C6300v2
I have an OBi200 ATA adapter connected my Netgear AC1750 C6300v2 and I have Aveno and Google Voice VoIP service associated with the OBi200 ATA adapter. 99% of my calls are made and received via Anveo...
  • AJA2024's avatar
    AJA2024
    Sep 11, 2024
    I resolved the matter by performing a reset (seven seconds) of the modem. I purchased the modem used and so the previous owner must have had settings (or the modem just required a reset) that was causing the issue I was having with Anveo VoIP outgoing calls.
