Buelle99
Oct 04, 2022Follower
AX1800 - Not connecting
We successfully connected the extender to our modem and all worked fine for 9 days. Today, it stopped working and said it can't find router. We reset and repeated the set up and still not working. ...
Oct 05, 2022Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
