afredwing
Oct 15, 2022Tutor
AX2700 Slow Speed
I have an AX2700 (cax30) modem and router combination. I am connected via cable to xFinity with a 800MBS speed/plan. According to my Nighthawk app my internet speed is 600MBS. My computer/phone is...
Oct 16, 2022Guru - Experienced User
Are you using smart connect?
If so, try disabling that. then test the difference in speed from the 2.4ghz to the 5ghz.
2.4ghz is a slow network and sensitive to interference. You should have your streaming devices and higher performing devices on the 5ghz.
