DFlo
Apr 30, 2023Aspirant
AX2700 WiFi Cable Modem Router (CAX30S)
Just installed a AX2700 WiFi Cable Modem Router (CAX30S) I am unable to connect my Dish Network receiver via the Ethernet cable. Says router not found. I also cannot connect one of my laptops wire...
michaelkenward
May 01, 2023Guru - Experienced User
The CAX30S is cable modem/router.
What is this "Dish Network receiver"?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
