KayDaTrevas
Jun 02, 2023Aspirant
AX6 router not supported
I just bought this router and it came with all of this information for Nighthawk. I followed the steps to set it up and connect to the internet but it says device not supported. I'm not sure what to d...
Jun 02, 2023Guru - Experienced User
Are you referring to the CAX80 gateway modem?
KayDaTrevas
Nighthawk AX6 Cable Modem Router
Model CAX30
Model CAX30
- FURRYe38Jun 02, 2023Guru - Experienced User
What ISP are you with?
Have you got on the phone with the ISP and support tech to have them associate the modem with there services?
