dubbob
Dec 30, 2022Follower
AX6000 Cable Modem Router Partial Service Mode
Hi all, been dealing with this issue for quite sometime. No splitters to remove, new ones were installed a couple months ago when ISP visited and said they could find nothing wrong with the line. T...
Dec 30, 2022Guru - Experienced User
Is this is the CAX80?
What FW is loaded currently?
I see power levels are a tad bit high. I'd ask the ISP to lower if possible.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Also see some correct and uncorrectables that should be zeros:
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
