ReachAMR
Feb 12, 2022Aspirant
AX80 AX600 To Work needs to be rebooted 2 or more times daily (Otherwise Incorrect Wifi Password)
I am not in IT so please keep it simple - thank you. I purchased this router a year ago and for the last several months, when I go to access the internet whatever device I am using will say the ...
Feb 12, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NightHawk (WiFi6 RAX and RAXE Series) router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
- ReachAMRFeb 12, 2022Aspirant
Thank you! Your answer may show how comlex this is... at the end of the day, people just want to it to work... I posted in the other page - please delete this (if you can) as I cannot delte my own post (or find a way to do so easily).
