HomeTown
Dec 22, 2022Aspirant
Bad tel 1 port? C7100V – Nighthawk AC1900 WiFi Cable Modem Router
I'm not getting a dial tone on any of my home phones. When I reboot my modem, the dial tone returns temporarily. But every few days I lose the dial tone again. My internet is working fine. Do I h...
Dec 22, 2022Guru - Experienced User
You could check with the ISP. there isn't much for settings for controls with those.
there should be 2 phone ports on it if you think its a port issue problem with the device.
You can also check the voice status when it goes down to see what its saying.
page 67/68 of the manual goes over that.
HomeTown
ISP says it's a problem with the tel 1 port. Do you think I should just get a new modem/router?
