sanddollarchic
Aug 11, 2019Follower
BEST ROUTER FOR CM1000 MODEM AND XFINITY
Looking for the best Router that works with the CM1000 modem and Xfinity... Trying to save money to get a router for under what a modem/router with a 3.1 docsys costs.
Router is mainly used for being on computer in one room and Netflix / Hulu watching and some light e-mail and surfing in another.
Looking into the AC 1200 or 17500 but will take others.. if work better and under $120.
1 Reply
You might find better feedback from the Nighthawk router users forum:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
.There are many routers that would probably work well for you.
Good Luck.
