rfabs1990
Nov 07, 2022Aspirant
Best way to extend C6250 cable modem/router range?
I currently have a netgear C6250 cable modem router combo. It has worked well for the longest time and I have a detached garage that I was trying to extend the signal to for a security camera and te...
rfabs1990
Nov 09, 2022Aspirant
Sorry my apologies! It's the model EX3110 (AC750 wifi range extender)
https://www.netgear.com/support/product/ex3110.aspx.
I'll have to plug back in and check it to verify, but I believe it was on the same SSID.
Nov 09, 2022Guru - Experienced User
the EX3100 isn't a mesh extender. So make sure to have it using a different ssid from the primary router.
Also, it isn't the fastest extender and is pretty basic. so only have devices connecting to it if they're in that zone that didn't have coverage or had poor service.
Overall, extenders are great at adding extra coverage and coving dead spots but if an area already has wifi coverage (so long as its half decent) they won't really boost speeds because of how they work.
