enguerrand
Jun 23, 2017Follower
Better performance
Model C6300, modem/router. Just bought - new ISP service (WOW) will be installed next week.
Box says ac adapter is recommended "for maximum performance." Is this the device I plug into the wall for electricity? If not, what is it?
Box also says "for maximum performance" with laptop I should use a Centrino adapter. What is this? (Note: I have a MacBook laptop I will be using.)
Thank you.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello enguerrand
You should be fine without the adapter and yes it just mean the power plug.
DarrenM
