Schweini
Sep 08, 2021Aspirant
blinking amber ethernet light
This is my second modem from netgear and this is the second dead modem. Both modems have the same problem occuring, the moment i buy them they are fine then around 2 months later they start doing thi...
Sep 09, 2021Guru - Experienced User
Be sure your using good quality LAN cables, CAT6 is recommended.
What is the Mfr of the host router thats connected to the modem?
- SchweiniSep 09, 2021Aspirant
I have a google onhub and a R6400v2. Both on new cat6. I've switched between both routers many times and they have the same problems. Even a direct connection to my pc form the modem causes the same issue.
- FURRYe38Sep 09, 2021Guru - Experienced User
Looking at the user manual on the CM modem to check LED behaviors: https://www.downloads.netgear.com/files/GDC/CM700/CM700_UM_EN.pdf
Ethernet
• Green. A powered-on device is connected to the Ethernet port at 1000 Mbps.
• Amber. A powered-on device is connected to the Ethernet port at 10/100 Mbps. <<<<<
• Blinking green or amber. The Ethernet port is processing traffic. <<<<<
• Off. No device is connected to the Ethernet port.- SchweiniSep 09, 2021Aspirant
Yes i know all of this already, i've done some research already. I was just having one last glimpse of hope for this modem to actually start being useful again. But i guess not, thank you anyways.
