Schweini
Sep 08, 2021Aspirant
blinking amber ethernet light
This is my second modem from netgear and this is the second dead modem. Both modems have the same problem occuring, the moment i buy them they are fine then around 2 months later they start doing thi...
Schweini
Sep 09, 2021Aspirant
I have a google onhub and a R6400v2. Both on new cat6. I've switched between both routers many times and they have the same problems. Even a direct connection to my pc form the modem causes the same issue.
Sep 09, 2021Guru - Experienced User
Looking at the user manual on the CM modem to check LED behaviors: https://www.downloads.netgear.com/files/GDC/CM700/CM700_UM_EN.pdf
Ethernet
• Green. A powered-on device is connected to the Ethernet port at 1000 Mbps.
• Amber. A powered-on device is connected to the Ethernet port at 10/100 Mbps. <<<<<
• Blinking green or amber. The Ethernet port is processing traffic. <<<<<
• Off. No device is connected to the Ethernet port.
- SchweiniSep 09, 2021Aspirant
Yes i know all of this already, i've done some research already. I was just having one last glimpse of hope for this modem to actually start being useful again. But i guess not, thank you anyways.
- FURRYe38Sep 10, 2021Guru - Experienced User
Other than this, is the CM modem working?
- SchweiniSep 12, 2021Aspirant
Yeah it works, i just bought a new cat 6 cable today and plugged both router and modem and it greenlit but speeds were still very low so I reset but now it wont go back to green light again. So now i know that it can even switch back to that channel, but I havent pinpointed the circumstances in which it does.
