Vanetommy2011
Aug 03, 2019Follower
Blinking Amber Ethernet port CM700. Insufficient speeds.
I Own a CM700 Modem and a Nighthawk XC AC4000 I have the Blast Pro! service from comcast goving me speeds up to 150mbps, but i recently took out some access points which were slowing my connection ...
Aug 05, 2019Guru - Experienced User
Try the modem back in the place where you had moved it too in the 1st place?
Be sure there are no coax line splitters between the ISP service box and the modem. Besure your using good quality RG6 coax cabling.
