Erin77
Aug 01, 2019Aspirant
blinking red ethernet light
Just activated new xfinity internet service with brand new CM500 modem- all lights are solid green except for the Ethernet light, which is blinking red. Xfinity customer service says my modem is activ...
schumaku
Aug 01, 2019Guru - Experienced User
Erin77 wrote:
Okay, the amber light is still blinking, ... My router (an apple airport express)...
Airport Express routers are supporting 10/100 Mbit/s only, so the amber LED is OK.
Erin77 wrote:
but now when I plug the Ethernet cord directly into my computer, the internet works on my computer just fine. When I plug into the router though, I can’t connect to the WiFi.
Wait. Your ISP will only allow one MAC address on the cable modem. If you had connected the computer before direct to the CM500 (e.g. to "activate the Internet") it won't issue a public IP address to your router WAN port. Power-off the router, reboot the CM500, wait some minutes, then power-up the router again.
The can't connect to the WiFi is a little bit vague - I would assume the router does come up anyway, and the wireless connection can be established, regardless if the router "has Internet" or not. However, some operating systems make users believe that if these systems can't reach the Internet, that the Wireless connection can't be established.
Erin77
I powered down, rebooted, powered back up, and no change.
