Sc
Jul 22, 2015Follower
Blinking upstream led light on c3700
Connected to Internet but upstream led blinking constantly
DarrenM
Jul 23, 2015Sr. NETGEAR Moderator
Hello SC
The upstream light typically should be solid the blinking upsteam light says that the unit is scanning for upstream channels to connect to. So are you having any issues with the internet being slow or lagging or is everything still working great? hope to hear your feedback
DarrenM
- MuddlesJul 23, 2015Aspirant
I've noticed the same problem. My Modem/Router is new but I was having an intermittant signal with my old one. It is a little better today.
I think it's my upload speed but not sure.
- DarrenMJul 23, 2015Sr. NETGEAR Moderator
Muddles
If you are having issues with the upload i would check all of your cable connections make sure they are tight also if you have a cable splitter between the modem and the wall coax this could be causing the signal issue. If this goes on may want to contact your ISP have them do some readings on the modem to make sure they are within the recommended levels.
DarrenM
- MuddlesJul 24, 2015Aspirant
Darren,
Thanks, tried all that and it's still blinking. I think it's a cable company issue but time will tell. I'll keep trying to figure it out.
Muddles
