Dboy501
Apr 28, 2020Guide
Blinking upstream light
It's actually a c7000v2. But the upstream light won't stop blinking no matter what I do, and it's been like this for 4 days. I e tried resetting it in every way possible, even a factory reset. I've al...
Dboy501
Apr 28, 2020Guide
Apr 29, 2020Guru - Experienced User
Other than the blinking, is it causing an issue?
- Dboy501Apr 29, 2020GuideYep. Wifi says "connected without internet" and my Xbox won't connect to Xbox Live. Here's a screenshot from today
- plemansApr 29, 2020Guru - Experienced User
You've got a few errors but nothing crazy.
Any splitters, attenuators, or amplifiers in line?
- Dboy501Apr 29, 2020GuideNope. Just the modem itself, with the only devices connected being my Xbox One X by ethernet, and my Samsung Galaxy S9 Plus by wifi, obviously. No matter how I reset the modem, it will go solid for maybe 10 minutes, and then flashing again, and doesn't show anything in the event logs. It still says (Honoring MDD; IP provisioning mode = IPv6) or "Unicast DSID PSN startup error" usually followed shortly by another error "Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out" after I reset it. But most of the time, it's a T-3 error. Seeing as how i've factory reset it 3 times now, and nothing is changing, i'm assuming it's a defective modem.
