Dboy501
Apr 28, 2020Guide
Blinking upstream light
It's actually a c7000v2. But the upstream light won't stop blinking no matter what I do, and it's been like this for 4 days. I e tried resetting it in every way possible, even a factory reset. I've al...
May 26, 2020Guru - Experienced User
If two different units have failed, then either this is a ISP line problem and the ISP needs to send someone out to check the signal at your place, or you have two faulty units.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Disable IPv6 option on the modems web page.
If anything find a stand alone mode and conenct a external router and see how that does, if it works better, the the problem is the C series modem.
Good Luck.
Dboy501
May 26, 2020Guide
There's no option to disable IPv6, only the firewall. There's no option set priority either. This sure is an expensive piece of equipment to have so few options in the administrative settings. I've been in talks with Xfinity's corporate office for about 2 weeks now, and they've escalated this to their tier 3 techs, because they've already been out here and replaced every single inch of their equipment on my property twice. The techs say they rarely come across a signal as clean as mine. It literally couldn't be more directly connected from the pole to the box, and from the box directly to my modem. From there it's just a cat 6 ethernet cable to my Xbox. I'm personally out of options, and since Netgear already replaced the unit, Best Buy won't touch it. So if this doesn't get resolved in the next week, i'm going to need Netgear to issue a refund. I've dealt with this for too long, and spent way too much money to recieve the lack of support i'm getting from both sides. I'm ready to take my refund and completely cut ties with both companies at this point.
- FURRYe38May 26, 2020Guru - Experienced User
You'll need to contact NG. Good Luck.
