Dboy501
Apr 29, 2020Guide
Blinking upstream light
It's actually a c7000v2. But the upstream light won't stop blinking no matter what I do, and it's been like this for 4 days. I e tried resetting it in every way possible, even a factory reset. I've al...
milhan
Sep 27, 2020Tutor
Hi,
I already talked to the ISP 2 days ago and asked them to check my connection and the agent said everything is normal. My modem is connected directly to the ISP cable; there are no splitters of any sort in between. I powered off and after several hours powered on several times in the past week and the same issue.
Sep 28, 2020Guru - Experienced User
milhan the ISP's first response is always "our line is fine".
I'd recommend starting your own thread and posting your cable connetions page and logs. That gives us a snap shot of your line info. I'd recommend starting your own so your info doesn't get confused with the OP's
