LA2
Nov 21, 2024Aspirant
Blocked MAC disappeared
I blocked a MAC address in the Orbi web version interface. I deleted the device in the Orbi android app too. Later, I found that this may be one of my devices. I went to the web interface to unblo...
- Nov 21, 2024
I finally got it to work! The mystery device is the ethernet device. When I tried to log in to the router the message that it is blocked in Access Control came up. I checked the Orbi web interface from another computer and it finally showed the device as blocked. No more hidden mac address. From the web interface I was able to allow it access. It works again! Thank you!
PS: sorry for messing up the discussion with the removed message content. I didn't know how to delete the message after it was posted.
LA2
Nov 22, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
