KyakpaSa
Apr 22, 2017Follower
Bought New Modem, Now I Have 3 Wifi Networks
Just setup new modem and everything works except i get 2 NetGear wifi networks and I still have my old one popping up. Wont this charge me extra money since im using a lot of wifi networks? Need help...
TheEther
Apr 23, 2017Guru
It doesn't cost extra money to have additional Wi-Fi networks. You can have as many as you want, within reason. For example, you can install additional Access Points throughout your place to provide better Wi-Fi coverage.
If you are sure that you have removed the old modem/router providing the old Wi-Fi network, then your device(s) may simply be showing the old network as a recently joined network. You can tell the device to "forget" it. Google forget wifi <os>, where <os> is either windows, osx, ios, or android to find instructions for removing old networks from your devices.
