roymi
Dec 03, 2019Aspirant
Bought Nighthawk X6 AC3200 router for Comcast Internet - Best modem to buy?
Hello everyone, I'm using Comcast for my internet, speed is around 240mbps I believe, going to increase this in the near future, if things go well to 1Gig. I only have internet and no cable (at t...
Dec 04, 2019Guru - Experienced User
If you're looking for modems and plan on gigabit I'd recommend either the CM1000 or CM1100. The difference is that the CM1100 has the potential for wan port link aggregation. The R8000 doesn't have this option but if the price is close, it gives you a future upgrade option.
I have both modems and they've been rock solid for me on Xfinity.
