roymi
Dec 03, 2019Aspirant
Bought Nighthawk X6 AC3200 router for Comcast Internet - Best modem to buy?
Hello everyone, I'm using Comcast for my internet, speed is around 240mbps I believe, going to increase this in the near future, if things go well to 1Gig. I only have internet and no cable (at t...
roymi
Dec 04, 2019Aspirant
Thank you guys seems like the cm1100, unless it's way more expensive than the cm1000 then the cm1000
roymi
Just saw the CM1200 at $179 at best buy, about $30 more than the CM1000, any compelling reason to get the CM1200? I see Best Buy doesn't carry the CM1100, strange.
- FURRYe38Dec 04, 2019Guru - Experienced User
The 1200 is about the same accept with additional WAN ports which ports 3 and 4 are for ISP address assignment only!!! These are not LAN IP address assigned ports in case you are curious.
