Golfnut123
Jul 20, 2020Aspirant
Brand new and having issues - 2.4g wifi won't connect to any devices
I just purchased a new modem/router and got it set up, but the 2.4g band won't connect to any devices. On my Roku, it shows an X for Internet connection, and my other devices (iphone, ipad and macbo...
Jul 21, 2020Guru - Experienced User
What firmware are you on?
What did you try? Saying "nothing fixed the situation" doesn't say what you've tried.
What modem is it connected to?
- Golfnut123Jul 21, 2020AspirantIt is a modem and router. The firmware is 1.03.04. I have Spectrum. I talked at length with them because the Netgear tech told me I need to upgrade the firmware to 1.02.09 for Spectrum. I talked to three different techs at Spectrum and they all said the firmware is automatically updated when they send a signal to it. I also tried changing the channel on the 2.4 to different ones (it was set on auto). I tried taking security off. I tried setting up a guest network on 2.4. I reset the modem using the reset button. I unplugged the modem and plugged it back in. In each case, my devices could see the 2.4g, but couldn’t connect to it.
- plemansJul 21, 2020Guru - Experienced User
If its a modem/router combo device, it isn't the R6300.
What model is it?
Was it sold/rented/given to you from the ISP?
You're ISP is correct in that they control the firmware on it. Combo devices have their firmware controlled by the isp.
- Golfnut123Jul 21, 2020AspirantIt is a C6300v2. I purchased it from Best Buy yesterday. The box indicates it is compatible with Spectrum.
