Amos1314
May 06, 2022Aspirant
Bridge mode c7000v2
I saw the post on how to do this and I'm able to make this happen. I've done it before but for some reason everything reset and I have to do this again. When I turn router mode off. I no longer hav...
txamasonrob
Jul 23, 2022Initiate
Hello All -
I was reading through the forum threads & this appears to be closes to the issue I am having so I decided to reply here for some assistance. I placed my C7000v2 into bridge mode & connected a laptop directly to it via ethernet. I can access all internet sites; however I am unable to access the router using 192.168.0.1 & my mesh router is not receiving a DCHP address so there is no accessing wifi from there or the mesh node. DOes anyone have any ideas why I would not be able to access the modem/router directly via ethernet?
This site can’t be reached
192.168.0.1 took too long to respond.
Try:
- Checking the connection
- Checking the proxy and the firewall
- Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
Check your Internet connection
Check any cables and reboot any routers, modems, or other network devices you may be using.
Allow Chrome to access the network in your firewall or antivirus settings.
If it is already listed as a program allowed to access the network, try removing it from the list and adding it again.
If you use a proxy server…
Check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don't believe you should be using a proxy server: Go to the Chrome menu > Settings > Show advanced settings… > Change proxy settings… > LAN Settings and deselect "Use a proxy server for your LAN".
