davidra
Dec 31, 2017Aspirant
Bridge mode
I want to try running a mesh wifi system (like Google, for example) with this combo modem/router. I assume I need to connect the LAN cable to the CG4500, plug it into the home mesh unit. I also assum...
DarrenM
Jan 05, 2018Sr. NETGEAR Moderator
That is a ISP specific cable modem that is supported by the ISP my guess is they have the feature turned off that lets you bridge the unit. You may need a different modem.
DarrenM
