benjedi420vt
Jul 21, 2021Aspirant
Broken WAN port, can I use LAN port R6900
Hi, To hopefully make this easier to navigate I've put my questions up at the top but to get the context please read below Q1: If the WAN/Internet/yellow port is dead, is there anyway to "remap"...
Jul 21, 2021Guru - Experienced User
If you go to your routers ip address + /debug.htm there used to be a map wan port to lan port 1
so if your address is 192.168.1.1 you'd go to:
192.168.1.1/debug.htm
- benjedi420vtJul 22, 2021Aspirant
Hi. Thanks for this response. So I went to the debug page and there was a option to check called
WAN mirror to LAN port 1
Is that what you were referring to?
Anyway, I checked it, unplugged my home network LAN cable from LAN port 1 and put it into LAN port 2. Then I unplugged my cable from the WAN port and pluged it into the LAN port 1. Then I rebooted the router.
The home netowrk seems to be working but unfortunately the internet is still out.
Ben
- plemansJul 22, 2021Guru - Experienced User
What modem is it?
Did you power off the modem and the router for 2 minutes,
then power the modem on, give it 2 minutes, and power the router on?
- antinodeJul 22, 2021Guru
> [...] there used to be a map wan port to lan port 1 [...]
"map" and "mirror" are spelled differently for a reason.
I know nothing, but I would not expect that feature to work as
desired. My (possibly dim) understanding of such port mirroring is that
it's read-only, intended to allow monitoring of the WAN traffic. I
would not expect it to allow (potentially) multiple simultaneous
transmitters on the same interface.A quick Web search for terms like, say,
router port mirror
might be educational.On my D7000[v1] (V1.0.1.78_1.0.1), I can find no such feature, so I
can't test anything, but I'd be at least a little amazed if it worked
the way you want.
With a dead/disconnected WAN/Internet port, I'd expect to see nothing
at all on a mirror port.
Irrelevant: The D7000 has a different feature on its debug.htm page,
"Save a copy of WAN interface packet trace", but I've never gotten that
to save Bit One, so I wouldn't mind having even a limited
port-monitoring feature. If it worked at all.
