rebeccar
Oct 07, 2016Aspirant
Brother states I need static IP address so printer can reconnect to network
Model C3700-100NAS
Brother tech support said that since the wireless printer drops from the network and and then won't reconnect as expected anytime my router hiccups, I should configure the router to hold a static IP address. There is no documentation online for this model nor do I understand any of the terminology. I am able to access my account and view the contents of the advanced tab. Can someone walk me through? Would it be ok for me to post a screen shot of the LAN Setup tab (if that's what I need) or would that violate my security? Thank you.
- rebeccarAspirant
To clarify, my printer is now configured for static address. If I understood correctly, I need to set the router to hold a static address, though I don't know how it should relate to the printer.
- Retired_Member
advanced........setup........lan setup....use address reservations........ after this done change printer BACK to DHCP
- rebeccarAspirant
Searay, do I simply check the button under '#' and take no other sction in the Netgear Gateway? Are you suggesting that I use a troubleshooting approach different from the one suggested by Brother? Can you explain in layman's terms what this is all about? Thanks
