kbish13
Oct 12, 2019Follower
BT Ultrafast G Fast compatibility
I wanted to pick your brains. I currently have BT ultrafast supplied by a dsl Gfast cable. I have an asus AX11000 which I want to use however I need a modem. Foolishly thining the Smart Hub 2 was lik...
Oct 13, 2019Guru - Experienced User
Check with your ISP first to see what brand modems they officially support.
Try to find a model modem that doesn't have a built in router first if possible. IF your connecting a external router, you really don't need a modem with a built in router already.
The AX11000 is a good router.
Please be sure to post about any DSL modem questions in the DSL Modem forum. This is a Cable modem forum.
Good Luck.
